bkcorwin avatar image
bkcorwin asked
Cerbo GX and GX touch cannot change or forget wifi network?
Hello, I have a cerbo GX in my new boat and I am trying to connect it to my wifi network. However, when I goto the wifi settings, I am unable to change the network. There is an existing hotspot from the previous owner that is no longer on the boat showing as the wifi network. However, there is no option to add a network, or to forget that network.
Does anyone have any suggestions?
cerbo gx
seb71 avatar image
seb71 answered ·
Can you post a picture with the screen/sub-menu where you are looking at?
mvdisconnect avatar image
mvdisconnect answered ·
Did you ever figure this out? I’m having the same issue.
johanndo avatar image
johanndo answered ·
img-20220824-204820.jpgThere is an option to disconnect / forget the network.
You can create a hotspot with the same name and produce an connection error, then go from there to change password or connect to something else.
you could also connect by BT and set up the WLAN connection.
