campdaily avatar image
campdaily asked
VE. Bus BMS charge disconnect MPPT & dc-dc chargers
Is it possible to disconnect two devices from the single charge disconnect point on a VE. Bus BMS? I'm planning to use a Solid Switch 104 to disconnect a dc-dc charger & a Battery Protect to disconnect solar charging. I believe that a MPPT should be connected to a battery all the time, so intend to use the Battery Protect to break the feed from the Solar Panels to the MPPT. Is this possible? Or is there a good reason noyt to?
MPPT Controllersorion dc-dc
