smoti avatar image
smoti asked
Low temp cut-off
Would just like to get one thing confirmed about the low temp cut-off in LiFePo4-mode of my smartsolar 75/15. If I use the smart battery sense with my Smartsolar 75/15 I understand the low temp cut-off just disable the charge from the Smartsolar and nothing else when the temperature drop below the trigger temperature. I can still pull energy out from the load terminals of the Smartsolar 75/15 even though the temperature is below the trigger temperature ?
Temperature Sensor
Victron temperature sensor disambiguation table - which product supports which sensor
