I am new to python, modbus & mqtt.
Having all this cool Victron equipment I thought I would give it a try.
AFAIK it works only on a *nix system console.
https://github.com/optio50/Victron_Modbus_TCP
OK, find the problem. I have no SolarChargerID, because the PV is from another system, going through et340 to multiplus-II GX device (a Kostal Piko 20 and a second Piko 7).
With comented out this Solar* section (and ouputs) - it runs.
Can you update your script to also poll devices like em24 device?
Bfo
Sorry, I am not familiar with those devices.
The script only communicates with VEbus modbus devices.
Hello, just tested it today and it work like a charm !
I found your project while trying to find a way to use teleinformation provided from Linky (french Linky electric meter ) as an energy meter (In place of ET112 Victron Module for example). I'd like to send it to VenusGX in order to adjust injected power in grid.
I'm totally new to programming, modbus, and would really appreciate any help :)
57 People are following this question.
