rubylove avatar image
rubylove asked
Ciryx as a standard relay
Hello, please, can I disconnect the techical ground (small black cable) to suspend the automatic function, connect the start assist at +12 (permanent) and use, technical ground just to control a relay? I want to use the ciryx ct 230A as a standard relay (on/off non automatic function
Relay
