Relay 1 is currently used as generator start/stop, and it works fine as is.
Relay 2 can be only manualy switched, or used as temp. relay as of sw2.80.
Any plans to enable Relay 2 to be used as Alarm output please?
I Often have no internet so getting email notification is not really helpful.
I hope this gets added to a future build.
Exactly what i also need. Why we can only use the relay 1 for this important function. Why we cannot chose Relay 1 for Alarm contact and Relay 2 for generator?
In a smart home you will have the cerbo gx in the technic room and nobody will here any alarm. This beeper should be included in the display + extra alarm relais!
Please add this feature , Already using Relay 1 for Gennerator and cant hear the alarm as Cerbo is in cabinet
darn phone rang and didn't hear the Cerbo due to it being in a cabnet as well.
I have already installed a piezo buzzer. Thats when I learned that relay 2 was not able to be setup as alarm output.
I would like to see all of relay 1's choices available on the other relays (Raspberry PI has 6 relay outputs). That way the installer can choose which of the 5 sources to connect to the available relays.
38 People are following this question.
