oliver-hutchison avatar image
oliver-hutchison asked
Cerbo GX replacement terminal blocks
Hello, I have managed to lose the power terminal block for my Cerbo GX so I'm looking to get a replacement but have no idea what the part is. There looks to be a few possible candidates when I look online.
As a short term fix I cannibalised the 8 way tank sender terminal block which was I was not using so would be nice to get a replacement for that too (I see there's a thread discussing this terminal block).
Cheers
cerbo gx
nebulight avatar image
nebulight answered ·
Here is the part number:
wj15edgkd-3.81
Wanjie is the name on the connector.
oliver-hutchison answered ·
When I search for that part number I get lots of 4 pole terminals. The power connector on my Cerbo GX was a 2 pole.
There's also no hits for anyone actually selling the part.
nebulight avatar image nebulight commented ·
Hmm, maybe someone at Victron can chime in, or maybe contact your dealer. Here is a crappy cell phone photo of the connector with part number:
oliver-hutchison avatar image oliver-hutchison nebulight commented ·
Thanks! That photo actually helps a lot.
Paul B avatar image
Paul B answered ·
Try you local Electronics store as the terminals are used on lots of other devices as well
Jcar or RS components - and other stores that sell electronic parts - this will be the quickest way to find a solution as I dont think many dealers would stock the plugs themselves.
Here is one link
https://fftech.en.made-in-china.com/product/aZjtVPHobmcI/China-High-Quality-3-5-3-8-5-0mm-Pitch-DIP-Type-Terminal-Cable-Connector-Termi-Blok-PCB-Terminal-Blocks.html
Based on the 2 answers above I'll be tracking down a standard 3.81 pitch 2 pole terminal.
Thank you both.
northtown2022 avatar image northtown2022 commented ·
Any luck finding these connectors in small quanity?
