peewag avatar image
peewag asked
Maximum AC output power with Powerassist on MultiPlus Compact 12/1600/70-16
Is the maximum AC output power of the MultiPlus Compact 12/1600/70-16 3600W (16A@230V) or is it possible to reach higher values with Powerassist?
If I use 16A@230V from the grid via the transfer switch and additional 7A@230V (1600W) from the inverter via Powerassist?
Thanks and best regards,
Peter
powerassist
The max output is 3600W (from grid) + 1300W (output power of the 1600VA MultiPlus).
