My Cerbo GX and a customers Cerbo GX both lost BlueTooth affecting Ruuvi temp sensors, a reboot rectified the issue.
Hi Wayne, is it ok if we log in remotely to check the logs? For that you'll need to enable Settings -> General -> Remote Support.
Is the system Valhalla?
Thank you, Matthijs
Yes, Valhalla, yes feel free any time.
The other system that dropped blue tooth at the same time is Allan + Esta's Motorhome, we both have the same Cerbo GX set up with Touch 50 (not RPi), they both lost BlueTooth at the same time.
We both have Ruuvi BT temp sensors, they were all still visible and enabled in O/I - BlueTooth Sensors, and all were still displaying in Device List as noted as "Disconnected".
We both also run Victron wired Temp Sensor that is monitoring hot water, the wired sensor was unaffected.
If of any interest it is Allan is the same customer I have posted about the VRM DC data issue with Linx shunt.
Cheers
Wayne
38 People are following this question.
