johnny-brusevold avatar image
johnny-brusevold asked
Venus OS Large 2.80-26 Node-red problem, value becomes array
I have a problem with the latest and a few versions ahead of venus-os large 2.80-Large-26.
This applies to node-red and reading of temperature data. Everything worked well before, but now the readings from the web page freeze after about 10 seconds, that is when input data changes value from normal value to array value
39.7
com.victronenergy.temperature.Rpi_cpu_id06 - / Temperature: msg.payload: number
to
com.victronenergy.temperature.Rpi_cpu_id06 - / Temperature: msg.payload: array [1]
[39.7]
Tried to troubleshoot but could not find the problem
Same problem with CpuTemp and RuuviTag
Node-RED
Hi @Johnny Brusevold , thank you for the report. We saw the same. Fix is coming. Matthijs
johnny-brusevold avatar image johnny-brusevold commented ·
Hi, @mvader (Victron Energy)
Tested v2.82_5-large-27 now. on pi 2, pi 3 b + with original image and pi4 with updated kernel. Temperature data seems to work well.
The only thing is these error messages that I get in message log, and is the same on all pi's normal, large and modified kernel. about 10kB per hour
Linux raspberrypi2 4.19.81-v7 #1 SMP Thu Dec 16 09:03:13 UTC 2021 armv7l GNU/Linux
  1. Feb 7 19:14:30 raspberrypi2 user.err kernel: [ 2332.767727] Bluetooth: hci0: Dropping invalid advertising data
  2. Feb 7 19:14:45 raspberrypi2 user.err kernel: [ 2348.230632] Bluetooth: hci0: advertising data len corrected
  3. Feb 7 19:14:52 raspberrypi2 user.err kernel: [ 2354.871357] Bluetooth: hci0: Frame reassembly failed (-84)
  4. Feb 7 19:14:52 raspberrypi2 user.err kernel: [ 2354.874031] Bluetooth: hci0: advertising data len corrected
  5. Feb 7 19:14:52 raspberrypi2 user.err kernel: [ 2354.876977] Bluetooth: hci0: Frame reassembly failed (-84)
  6. Feb 7 19:16:37 raspberrypi2 user.err kernel: [ 2459.604980] Bluetooth: hci0: advertising data len corrected
EDIT
Figured it out. This is when ruuvitags are switched on (2 pcs.)
Have scanned for bluethoot devices, but there are only these two
4577 and 7A5E. and the nearest house is 100m away There are more in the list than the picture shows, and it is growing all the time
