Is it possible to mix MultiPlus II inverters in 3 phase system? For example one 5kva model and two other 3kva? Or have 4 inverters - two sitting on phase 1 and other two dealing with phase 2 and 3?
Anyone build such system?
All of the units within a system must be that same model. You cannot mix different size or model units in a multi phase or single phase system.
Here is the documentation:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
My Victron installer told me that only size of the inverter and its model must be the same in the 3 phase system. Number of units per phase does not have to be the same.
Soon I will test it in my system. I am waiting for a warm day to do it.
42 People are following this question.
