I need a little help. I would like to connect my bmv 712 to my ccgx to utilize the relay to trigger my 12v water heater element when batteries are near full. I am already using the relay in the ccgx to start my Onan Generator. I have a multiplus 3000 12v, mppt 185/90. The ccgx is connected to the smart shunt. I have the Ve direct connected to the smart shunt and the mppt controller. Ve bus is connected to multiplus and dig multi controller. What I have left are the two Ve can and 1 usb connection. Is it possible to wire this into the system? Where does the bmv712 get it power? I also have the shunt that goes along with the bmv712 if i can incorporate that into the system
