petertmac avatar image
petertmac asked
Cannot see second JBD BMS after Update
Hi Louis,
Up until today I have been running Venus OS 2.73 and Serial Battery 0.9 on my Raspberry Pi and was able to see both of my JBD BMS's.
Today I added some Ruuvi temp sensors to my system and had to update to Venus OS v2.80~44. After the update I can only see one of my BMS's. Tried updating to Serial Battery v0.1, but unfortunately still can see only one BMS.
All good if I rollback to v2.73 but then unable to integrate Ruuvi sensors.
Any idea what my problem might be?
Thanks,
Peter
BMS
Louis van der Walt avatar image
Louis van der Walt answered ·
Hi @petertmac
I have the same problem on the V2.80 firmware. The problem seems to be that the serial-starter services says it starts the driver, but it never calls the driver.
I have had no replies to my post about this issue yet, so am a bit stuck.
https://community.victronenergy.com/questions/116490/serial-starter-not-always-starting-driver-v280-for.html
petertmac avatar image petertmac commented ·
Thanks Louis,
Just read your thread and my logs show the same as yours. Hopefully it will get resolved at some point.
