I want to operate an electric anchor windlass using the start assist for longer than 30 seconds, so if I connect the +ve up anchor switch to the Cyrix start assist wire, will the cyrix stay closed as long as that button is pushed?
Yes, you can connect a toggle switch (your anchor switch) to hold the relay closed for as long as you want.
However, you'll have to remember to switch it off after you have finished using the windlass.
From the manual, third sentence:
The manual:
https://www.victronenergy.com/upload/documents/Manual-Cyrix-ct-120-EN-NL-DE-FR-ES.pdf
Thanks, the anchor windlass "up" switch is a momentary switch and so is turned on and off a number of times during the process of raising anchor. To some extent the Cyrix will be acting like a solenoid letting high amp flow to the anchor windlass each time the up button is engaged, (and I suppose for at least 30 seconds at a time). Current is passing through an 80 Amp breaker so the cable and Cyrix are protected. The signal wire will be fused as well. I m wondering how robust this unit may be when used for this purpose because it is described as an emergency switch . My alternative is of course to install a proper solenoid (leading to the windless contactor) on a separate cable by-passing the Cyrix.
24 People are following this question.
