ecooper avatar image
ecooper asked
Cerbo GX bluetooth
Cannot seem to pair. Asks for the "code" on the unit. Please ID the "code" on the unit.
cerbo gx
ecooper answered ·
This is the question. Enter the code shown on ... What code? default does not work!
Try to reset the PIN with the PUK.
The PUK should be on the sticker on the Cerbo.
Kevin Windrem avatar image
Kevin Windrem answered ·
The GX device has a place to enter the bluetooth PIN. It may not be set to six zeros.
You may also need to remove the GX device from your phone/tablet bluetooth menu, then relaunch VictronConnect and try again.
ecooper answered ·
Tried all of your suggestions before I ask the question. Is "code shown on Cerbo GX ..." an incorrect error statement?
Kevin Windrem avatar image Kevin Windrem commented ·
Victron devices is not like other bluetooth things in that a code does not pop up on the device saying enter this number.
For many Victron devices, there is no way to see the pin from the device. These have a PUK printed on a label attached to the device that you can use to reset the PIN. Cerbo is not like that either.
Go to Settings / Bluetooth. There you will see and Enable on/off and if on a Pincode. That's the number you'd enter from VictronConnect.
ecooper answered ·
If so, what is the work around. This was a new unit. Is it possible that it had a PIN in it (other than the default) when I got it? How can this PIN be reset to the factory default?
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi
The Cerbo will setup its own Wifi network. You can connect to this network using your phone or laptop. The name and password of this network are available on the sticker on the Cerbo. You should then be able to open http://venus.local in a browser and get the remote console. This is the normal gui of the Cerbo. Using this, it should be possible to set the bluetooth pincode or set the wifi connection.
Kind regards,
Thiemo van Engelen
