marco-lingua avatar image
marco-lingua asked
Raspi3b+ help with ADC
Hi everyone. I have installed Venus OS on my RPI (ver.2.80-41). I would like to be able to program the analog inputs to connect the tank level probes but I can't. I looked at several pages on this forum but to no avail. I'm using MCP3208. The problem is that from terminal I can see the values of the connected probes (cat /sys/bus/iio/devices/iio\:device0/in_voltage[0-7]_raw) but I don't see them on the rpi GUI. What am I doing wrong? Ideal would be a step by step guide because I no longer remember all the steps that I have done or have not done. I've been on it for a week!
Raspberry Pianalog
Rob Duthie avatar image
Rob Duthie answered ·
Do you have the below files in folder called dbus.adc.conf in the etc/venus/ folder?
device iio:device0
vref 1.8
scale 4095
tank 0
tank 1
tank 2
tank 3
temp 4
temp 5
temp 6
temp 7
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
