jetkit avatar image
jetkit asked
Argo FET for 2 alternators, 3 batteries
Replacing an old diode battery isolator here. The original was simple, with two inputs and 3 outputs.
Argo does not have a FET isolator with two inputs.
I was suggested to use two Argofet 100-3, and connect the outputs in parallel. I created a simple schematic of my understanding. Can someone with expertise on those boys to chime in?
Argo FET Diode
priba avatar image
priba answered ·
Hi jetkit, same here :)
Picture is from last weekend. Note there are inputs from alternators and some other wires missing.
I was assuming it will work and had found confirmation on a YT channel PYS.
Will have first hand info in two weeks when I'll do the test.
I have some other concerns regarding return voltage to INPUT in this state (picture) but I don't want to highjack this thread.
priba
priba avatar image
priba answered ·
Tested last weekend and sure it works.
Not that I did extensive testing because my batteries were fully charged.
I didn't measure current passed to each battery bank but voltage was present and there was no voltage drop across input/output terminals.
priba
eien avatar image
eien answered ·
I would have mounted a splitter with two inputs and three outputs, cheaper and less wiring.
