sfg avatar image
Multi / Multiplus 12 500 20 inverter/chagers
What are the differences between a Multi 12 500 20 and a Multiplus 12 500 20? Thank you
Help
Do you have a link to that Multi 12/500/20 without "Plus" ?
In the official pricelist is only one Multi without "Plus" the Multi RS.
All others are official named MultiPlus but they are also often just called Multi
Definitely Multi as per wkirby link below
wkirby avatar image
wkirby answered ·
The main advantages of MultiPlus 500VA over the Multi 500VA are:
Parallel and Three Phase capability.
Power Assist
Power Control
The details are in paragraphs 2 - 4 of this datasheet:
https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-500VA-2000VA-EN.pdf
The Multi 500VA does not offer those features in paragraphs 2 - 4.
4 comments
Is that some kind of special product for a small marked or an EOL product or something?
I can't find anything about that.
Edit: I found something in the old manual section. It seem like to be an EOL product, the first Multi(Plus) in the new plastic case.Looks like it was only available for around 2 years between late 2016 and early 2018.
wkirby avatar image wkirby ♦♦ Matthias Lange - DE ♦ ·
I found a "Multi 500VA" document hosted elsewhere:
http://barden-uk.com/wp-content/uploads/2016/10/Datasheet-Multi-500VA-EN.pdf
sfg avatar image sfg Matthias Lange - DE ♦ ·
It is definitely EOL.
It is not in the pricelist since Q1 2018.
