info-6 avatar image
info-6 asked
Main Switch on Multiplus
Hi there,
I have two simple questions about the main switch on Multiplus 12|3000.
1.) If the switch is "OFF", will any externally connected AC-power go through to AC-out 1?
2.) If the switch is "ON", but on the Digital Control the switch is "OFF", will any externally connected AC-power go through to AC-out 1?
Would be pleased to receive a clarification
MultiPlus Quattro Inverter ChargerDigital Multi Control
info-6 avatar image info-6 commented ·
Thanks for swift answer, @Matthias Lange - DE
I read the manual, but may I should have had a look to appendix B. :-(
piraya avatar image
piraya answered ·
This is In fact a very interesting topic because sometimes I would like to turn off the charging but keep electricity in my outlets. Any easy to use solutions for this?
You could use a switch relay to switch AC in from multi to bypass it. But get professional advice.
