mark-rolle avatar image
mark-rolle asked
150/70 MPPT relay operation
Will the programed relay output operation of 150/70 continue to work (sensing a set batt voltage) if the remote is turned off by another sensor (BVM712)
Relay
wkirby avatar image
wkirby answered ยท
My unit's relay responds to the "Battery Voltage Low" settings regardless of the state of the remote input.
mark-rolle avatar image mark-rolle commented ยท
Thanks for your reply....are you able to confirm if it will respond to a high voltage event as well?...thanks
0 Likes 0 ยท
