bader-eddine avatar image
bader-eddine asked
[Urgent] Configuration of programmable relay - Victron MPPT 150-60
Dear support team,
we urgently need your help, in our current project, we are working with Victron MPPT 150-60 model, we need to export a same hardware alarm from the MPPT ( high battery, low battery,...) using the programmable relay .
In the user manual, the programmable relay offre three connections
• NO (Normally Open)
• C (Common)
• NC (Normally Closed
Therefore, i would like to know, if it's possible, can i configure the relay for example to export two-alarm, Between the NO-C contact the High battery alarm, and C-NC contact the Low battery alarm.
Thank you in advance.
Relay
wkirby avatar image
wkirby answered ·
One contact is always closed.
NO will be closed if the relay is energised.
NC will be closed if the relay is de-energised.
There is never a circumstance where both will be open. If you wire how you suggest, you will always have one alarm or the other.
