kuperusron avatar image
kuperusron asked
cerbo GX power from Orion -TR not visible in total calculation
on touch 50 display only the BMV712 current results (totals) are visible and not the power consumed / delivered by multiplus 12/500 and the calculated difference delivered from orion -TR smart.
expected to have visible:
currents to from multiplus inverter/charger
and from BMV717 the battery current
The difference would be then the current out of the orion-TR
Is this a correct assumption, also the item DC load is not visible on touch 50.
cerbo gx
kuperusron avatar image kuperusron commented ·
Problem solved, use selection system setup and select Has DC System then additional power feed is visible.
bathnm avatar image
bathnm answered ·
Have you turned on "Has DC System" under System Setup.
This is a calculated value, which mill show the difference between battery, inverter (DC) and solar through a calculation.
