Could you post a simple example of a python program to log in to VRM API and return a piece of data, eg SoC of batteries please? I have been going round in circles for hours and just can't get the simplest thing to work!
I have spent way too long on this! I came up with an answer and I will put it here for anyone else going down this rabbit hole. Probably me in a few months.
import requests
import json
login_url = 'https://vrmapi.victronenergy.com/v2/auth/login'
batterysummary_url = "https://vrmapi.victronenergy.com/v2/installations/93772/widgets/BatterySummary"
#use your own victron installation id instead of "93772"
login_string = '{"username":"name@domain.com","password":"password123"}'
#use the name and password you log in to VRM with
response = requests.post(login_url , login_string)
token = json.loads(response.text)["token"]
headers = {'X-Authorization': "Bearer " + token }
response = requests.get(batterysummary_url, headers=headers)
batterySOC = response.json()["records"]["data"]["51"]["valueFormattedWithUnit"]
print("Battery SOC is ",batterySOC)
The magic number "51" is the field for SOC. Look in the variable "response" for more such magic numbers
instead of batterysummar_url you can also try :
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/BMSDiagnostics
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/HistoricData
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/IOExtenderInOut
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/LithiumBMS
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/MotorSummary
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/PVInverterStatus
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/SolarChargerSummary
https://vrmapi.victronenergy.com/v2/installations/93772/widgets/Status
This document gives some details : https://docs.victronenergy.com/vrmapi/overview.html#retrieve-diagnostic-data-all-current-installation-data
Actually, forget all that above. Those magic numbers change over time! use the field "code" to tell find the element you want. You can get all the important stuff from the diags message :
import requests
import json
from datetime import datetime
diags_url = "https://vrmapi.victronenergy.com/v2/installations/93772/diagnostics?count=1000"
response = requests.get(diags_url, headers=headers)
data = response.json()["records"]
batterySoC=[element['formattedValue'] for element in data if element['code']=="SOC"][0]
batterycurrent=[element['rawValue'] for element in data if element['code']=="I"][0]
solarpower=[element['formattedValue'] for element in data if element['code']=="Pdc"][0]
loadpower=[element['formattedValue'] for element in data if element['code']=="o1"][0]
generatorpower=[element['formattedValue'] for element in data if element['code']=="gs1"][0]
timestamp=(datetime.fromtimestamp([element['timestamp'] for element in data if element['code']=="SOC"][0]))
print("SoC : ",batterySoC)
print("Battery charge / discharge (A) :" ,batterycurrent)
print("Solar power : ",solarpower)
print("Load : ",loadpower)
print("Generator : ",generatorpower)
print("data taken at : ", timestamp)
Hi everyone,
I am currently running a python script to get data from VRM. For data such voltages and current everything is working, but when I try to get alarms or error codes the json file shows null or none where there was a error o alarm.
Does anyone know how to properly request and get alarms and errors log?
I am looking at the same problem, i want to get all data into python from VRM, but i also want to control the inverters. I have only seen the solution with nodered, but i cant access that from python. You have any ideas?
29 People are following this question.
