tracy avatar image
tracy asked
How to turn on the multiplex victron inverter from cerbo panel
Traveling in cold weather and fridge on that we are sure of…..plugged in slow cooker and it was working but then we stopped overnight and nothing came on when we returned to van in the morning.
the panel says it is off so how do we get it back on? The batteries are now full and we are in warmer weather.
victron community
Alexandra avatar image
Alexandra answered ·
@Tracy
Sometimes you have to use the rocker switch on the front of the inverter.
On the Cerbo under device list - Multiplus - there will be the switch options.
tracy avatar image
tracy answered ·
We don’t have the rocker panel…..however we just stopped and the light came back on the inverter and everything is now working.
So is it that when it is too cold we should not use the fridge or outlets until we get to warm weather? Was it a safety mechanism to shut things down because we were pulling electricity when it was too cold?
What batteries and inverter do you have in your setup? Some batteries switch off when they are too cold as well.
