dave-jones avatar image
dave-jones asked
Wind Turbine integration to 12v victron set up
Hi All
We currently have a 12v off grid solar setup with two 100/50 mppts that just doesn't keep up over the winter. This system is controlled and monitored with a Cerbo GX. Weve decided to add a Rutland 914i turbine with a hrdi controller as it appears suited to the weather conditions, high winds due to living on an open moorland.
If the hrdi controller is connected directly to the system would this interfere with the solar charge? Or would it be beneficial/work to have the hrdi battery output connected to 12/12-30 or 24/12-30 dc to dc charger either with or without an additional battery between the hrdi controller and the 12v system were looking to charge?
Hydro and Wind Power
