Ryan klapper avatar image
Ryan klapper asked
where does the Cerbo/GX Touch draw its voltage reading from?
Hello, I have a customer with an issue and Im out of country right now. He installed his own multiplus, cerbo gx and touch 50.
When running a load on the multi. His voltage is 12.8 on the bmv712.(matches what is at the main bus bars) But 12.1-12.2 on the touch 50 .
What can cause this discrepancy?
Where does the touch 50 draw it's voltage reading from?
Thank you
cerbo gx
Hi, Cerbo/GX touch draw their voltage reading from the bmv, by default.
and there is an option to prefer the multi.
See Settings -> System setup
Also in the manual.
success!
Ryan klapper avatar image Ryan klapper commented ·
Thank you, then I'm really curious why almost any volt discrepancy between the blv and the touch50?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ Ryan klapper commented ·
Hi, you need to check that setting and/or in the Device list on the GX Touch see which devices shows what reading.
and then in most cases its due to a bad connection, and thus voltage drop. So take a multi meter out and measure where the issue is.
Thats all I can advise so remotely I’m afraid, success!
