Csaba Köböl avatar image
Csaba Köböl asked
RS450/100 too low numbers?
I just extended my install with Victron MPPT 450/100 but getting very low numbers and doesn't seem to be right, my solar panels are JA 540MR in 5S oriented to the east, so from 8am-12pm I anticipate at least 500W (1100W/m2 installed x 0.1 sunny winter coefficient ) but getting 0-30W . Any idea why this is happening?
mppt chargingmppt rs
It is not easy to guess with only one screenshot.
Check the connection between the MPPT and the battery.
Is the remote on/off jumper plugged in correctly?
5 comments
Csaba Köböl avatar image Csaba Köböl commented ·
I will do the check when I'll be back there. Thanks.
Problem solved :) Thank you.1641119975492.png
klim8skeptic avatar image klim8skeptic ♦ Csaba Köböl commented ·
1 mppt reads a voltage of 0.9 v.
Bad kama.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ klim8skeptic ♦ commented ·
I guess there is nothing connected.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Csaba Köböl commented ·
It would be good to know what the problem was. This will help others in the same situation.
Alexandra avatar image
Alexandra answered ·
@Csaba Köböl
You seem to have a double instance of the mppt there (or at least the serial number is very similar), or do you have two in the system? If it is s doube instance then that may be the issue.
If you do have two, then the one is not registering panel voltage. So check those connections.
@Alexandra
The RS 450/100 has two MPP tracker inside and both are shown on the VRM portal.
(the RS 450/200 has 4 trackers)
