How do I connect Fronius Primo 5.0-1 WLAN / LAN / web server to Victron MultiPlus-II 48/3000 / 35-32? Are there drawings available?
for this, you need a GX device.
See here (2. GX Devices & Fronius PV Inverters): AC-coupled PV with Fronius PV Inverters [Victron Energy]
Are GX este modelul cu trei componente: EasySolar-II GX , MultiPlus-II 48/3000/35-32 (ACOut2 comutabil) , SmartSolar Charger MPPT 250/70
Has GX is the three-component model:EasySolar-II GX ,MultiPlus-II 48/3000/35-32 (ACOut2 switchable) ,SmartSolar Charger MPPT 250/70
Basically, you just need to connect the LAN ports of the Easy and the Fronius with a straight LAN patch cable.
BR
42 People are following this question.
