I want to monitor my AC loads on my Sigineer 3K 24v split phase inverter, can I use the ET112 to do this?
This is a Victron community so you will unlikely find your answer here for your inverter. The ET112 is also not a Victron manufactured product, but from Carlo Cavazzi that is tested compatible with Victron. As for using a Cerbo, (refer your other post) which is not a standalone product and intended for use with Victron inverters, you may well be out of luck.
30 People are following this question.
