tom4x avatar image
tom4x asked
Components for extendible off-grid system
Dear community,
I'm new to this place and would like your feedback if I understood the Victron components' abilities and purpose correctly as there is such a large amount of different products.
The aim is a system for one household which can work off-grid and if grid is available, as UPS or supporting the gird. Feed-in is neither possible nor desired. Also, it should be extendible for both more panels and more batteries.
Obviously I aiming for the Muiltiplus, whereas I'm not sure of I need the Multiplus II or if an older Multiplus is also sufficient. On the battery-side, I plan for 24V (battery type yet to be defined).
As the Multiplus' advantage is that the current from the panels could come in on the DC side as well as on the AC side, I could then connect panels with (one or multiple) BlueSolar/SmartSolar charger to the batteries plus to Multiplus on DC-side, right? And additionally I could connect panels (could be ones which are farther away) with a line-communted inverter, is that correct? May I also use (multiple) micro-inverters on the AC-side safely?
Thanks for your answers in advance
Tom
MPPT ControllersMultiPlus Quattro Inverter Chargeroffgrid
seb71 avatar image
seb71 answered ·
Change this part of the plan: go for a 48V battery.
Battery type: choose LiFePO4.
