I have Multiplus 3000 and two battle born Lithium batteries in parallel. The trailer is plugged into my house’s 30amp. The float voltage is set to 13.5v. The Smart Shunt is connected to the batteries terminals and the Smart Dongle is plugged into the buses. When Multiplus is in float mode and DC load is running, I noticed sometimes the power was pulled from the batteries and sometimes the Multiplus charged the batteries. The voltage is bouncing up and down. I set the Multiplus to charger only, it’s the same. Is it normal the batteries got charged/discharged cycle in float mode and the voltage bounces? Should I disconnect the battery when plugged in to avoid cycling the battery?
![b964a212-4fe3-47b6-ab8e-3970dfabe3ad.jpeg](/storage/attachments/26930-b964a212-4fe3-47b6-ab8e-3970dfabe3ad.jpeg)
