emmanuel-allaud avatar image
emmanuel-allaud asked
Is it possible to use an automatic transfer switch to switch a PV inverter between grid and AC-out?
I would like to use a PV inverter to feed the grid exclusively when the grid is up and when the grid is down switch the PV output to the multiplus (AC-coupled then) so that it produces to feed my loads locally.
I would like to use a Victron VE transfer switch to do that (see circuit).
capture-decran-de-2021-12-18-12-55-02.pngTranslations: "Vers réseau" = Towards grid ; "Charges critiques"=Critical loads
Is it possible? How to control the switch depending on grid state?
TIA,
Manu
AC PV Coupling
