yeswhynot avatar image
yeswhynot asked
Which fanless chargeror powersupply can be set to specific parameter ?
hi i m new in this universe , i search for a silent charger so probably fanless that i can set for for a wheelchaire (2x 12v 75ah) charge voltage and
. Keep going until the current falls to a very low level around 1000 of capacity, or falls by less that 0.1A over an hour. Then its full.
or set the float voltage to a certain voltage.
!any suggestions?
2 can the charger be used for agm and gel batteries provided i change its setting?
3 how hard is it for a custumer to set those numbers?
psim in canada so 120 wallplug.
pps if possible charging at around 25 amp but if not possible 12 or 13 amp could be ok
chargerbattery
Alexandra avatar image
Alexandra answered ·
@yeswhynot
I use the IP65 charger for my 12v stuff
Pretty easy to use and set up with a profile and victron connect for monitoring and has some neat accessories for plugging and unplugging from it.
yeswhynot answered ·
hi
do you have the experience to answer the questions 123? tx
Install the VictronConnect app and take a look at the demo library.
@yeswhynot
I answered these in your other question.
hi could you paste a link to what you call the library demonstrator?
thanks
https://www.victronenergy.com/support-and-downloads/software
You need to download and install the VictronConnect app on your phone, tablet, PC, laptop or Mac.
Chargers.
