diego quintero avatar image
diego quintero asked
Multiplus Constant Battery Discharge Current without relaxation
I have a system with a Multiplus and Venus and BMV.
I know that Victron Multiplus can only be control base on power input per phase ( or am I wrong?). However, is there a way to keep the current constant while the battery discharges?. In all the plots I see, the discharge current start changing to keep the power while the voltage is reduce, but this is not my goal, I just want to see the real battery capacity base on Current.
Thanks for your help.
Multiplus-IIESSinverter current draw
kevgermany avatar image
kevgermany answered ·
I think you need to add a BMV and shunt.
Sorry, missed your statement about BMV.
How is it wired/configured?
diego quintero answered ·
Thanks for your help. Yes the system has an BMV.
I just want to create a DC plot with the multiplus in which the current is kept constant until the battery reaches the minimum voltage value without changing the current.
VRM shows a plot of the battery in/out current measured by the BMV. It will also show battery voltage.
