jond avatar image
jond asked
Multiplus II turning off
Multiplus 5000 had no lights on switches off periodically.
it is 5kva with Revov Lithium batteries and the Revov communication hub. Swapped with another Multiplus, same issue. Cerbo Cerbo GX installed. No MPPT/panels.
It looks like the multiplus and the battery BMV is giving different voltage readings,
Battery Specs:
Designed Cycle Life 7000+ cycles Nominal Voltage 51.2V Nominal Capacity 100Ah Energy 5.1kWh Max Current 100A Recommended Recharge 3 Hours at 40A Boost / Absorption Voltage 54.3V- 55.5V Float Voltage 54.0V- 54.5V Suggested Discharge cut-off Voltage 48V Standard charging Current 40A Recommended Discharge Rate 0.6C Size: Length x Width x Height 480mm x 420mm x 177mm Weight 42kg
Multiplus-IILithium Battery
nickdb avatar image
nickdb answered ·
You're really going to have chat to your revov supplier about correctly configuring the victron system, as it is not on the compatibility list, and if the BMS isn't playing nice, you will have problems.
