jdm avatar image
jdm asked
BMV SOC not changing when manually trying and Lithium CV .
I have a system comprising of 2 x lithium super packs 25.6 x 50Ah, smart BMV , Easysolar w/CCGX , Smart shunt( measuring current from the B2B) and Orion.I've got some doubts about the SOC as it doesn't seem to change more then by 20% before it shuts down ( as the batteries have shut down a couple of times), and I can't manually set it to a value that I want say if I wanted to set it to 50%. every time I try it just reverts back to 100%.
Remote monitoring is offline at the moment which would tell me more :/
Is is correctly wired , I think it must be a settings issue . any ideas anyone I know that I need to change the discahrge floor to 15% as I have seen its at 0% at the moment , which is a mistake. alos efficieny is 95% vs 99%. also with Lithium does it make a difference to have the charged voltage set below float or absorb levels .
thanks Community !
BMV Battery MonitorSOC
seb71 avatar image
seb71 answered ·
Disable "Battery starts synchronized" if it is enabled.
Also check when you start from SOC 100% if the battery actually is at 100% (measure the battery voltage).
That setting does only matter for the "time to go/time remaining" calculation.
jdm avatar image
jdm answered ·
Ok thanks , It is enabled , so will change
Battery voltatge definately hits the absorb , and I've beeen getting to float with the AC in.
thanks ! it says infinite currently!
kevgermany avatar image
kevgermany answered ·
If you disable start at 100,% it starts at zero and gives a low battery alarm.
You may want to look at tail current, voltage settings in the BMV as well.
jdm avatar image
jdm answered ·
Ok thanks will feedback
Victron BMV battery monitors product page
