I dont know which is the correct one for me: EasySolar, EasySolar II GX, Multiplus Compact, Multiplus I or II (+separate solar charge controller) or something else.
I tried contacting Victron representative for our region, but he is "AFK".
Afik there isn't a Victron all in one unit that does everything you want.
You're going to have to have multiple units. And compromise. Best to sit with the distributor and go through all the options. How long AFK?
Ultimately it will come down to which trade offs are most acceptable for you.
"AFK" from 24 Nov, so...
It is a off grid solar system so no mains are near, only generator as a source of AC. What is a dual DC voltage?
Is Easy Solar II fully programmable thru BT?
Dual DC is from your first post. 24V battery and some 12V loads.
Easysolar II GX has WiFi interface for GX controler and BT for included MPPT 250/70.
Suggest choosing 48V ES-II unit.
So mppt charger + Multiplus II +70€ usb cable (PC Victron MK3-USB interface (VE.Bus to USB)
) could also be a way to go?
Look at Victron price list and make informed decision.
24V system
EasySolar-II 24/3000/70-32 MPPT 250/70 GX € 1.924,00
or
MultiPlus-II 24/3000/70-32 € 1.342,00
Cerbo GX € 300,00
SmartSolar MPPT 250/70-Tr € 750,00
VE.Direct Cable 0,9m € 15,00
Total = € 2407,00
48V system
EasySolar-II 48/3000/35-32 MPPT 250/70 GX € 1.924,00
or
MultiPlus-II 48/3000/35-32 € 1.060,00
Cerbo GX € 300,00
Total = € 2125,00
You will also need with any system
Interface MK3-USB (VE.Bus to USB) € 70,00
You could go with GX version of MP-IIs but Cerbo is a better choice and cost is the same.
For me, not clear what you want.
Do you have loads apart from AC and 12V? Specifically 24V.
You have no monitoring in the system. E.g. BMV712.
"I would like to power AC 240V loads around 2000W - only during daytime, and some 12V small loads - 10-50W) ", so no 24V loads.
32 People are following this question.
