darius avatar image
darius asked
dbus API specifics for battery monitors
I have a mobile coffee van with a Victron Multiplus and an enerdrive ePro battery monitor (the battery monitor predates the Multiplus which is why it's not a Victron unit).
I have setup a Rasperry Pi running Venus for monitoring both and it's working well (my congratulations to Victron for making it open source and highly flexible!). I wrote a program to parse the ePro serial data and write to dbus which seems to work however I was wondering if there is any specific documentation about exactly what paths mean what (I got the list of paths from dbus_systemcalc.py)
For example I am not sure what the difference between "/Dc/0/Current" and "/Sense/Current"?
My code is at https://www.dons.net.au/%7Edarius/hgwebdir.cgi/epro/file/tip/eprodbus.py if anyone wishes to use it or copy it. It should probably be integrated with serial-starter but this works for now ;)
Venus OS
Louis van der Walt avatar image
Louis van der Walt answered Ā·
I think this is what you are looking for
https://github.com/victronenergy/venus/wiki/dbus
If you want to contribute your code to my serialbattery driver to add ePro, that might be a good place for your code.
https://community.victronenergy.com/questions/76159/victron-venusos-driver-for-serial-connected-bms-av.html
darius avatar image darius commented Ā·
That is exactly, thank you very much.
I guess my search-fu was not up to scratch :)
I'll take a look at submitting a pull request for the ePro to you code.
0 Likes 0 Ā·
darius avatar image
darius answered Ā·
I had a look at serialbattery but it seems very geared toward lithium BMSs whereas the epro is purely a battery monitor (for lead acid batteries) so I don't think I can fit my code in nicely.
