msaaby avatar image
msaaby asked
AC loads not correct (VA instead of W?)
Hi
I have setup a RPI4 running Venus OS.
I have a Victron Shunt, Victron Inverter, Victron MPPT all connected with usb.
As you can see below it says I have a DC power of 118W (I don't have a DC Power)
Below is from my shunt showing 332W. (I have measured it and get the same result)
Below is a screenshot from the inverter showing 465VA (not W).
I think the 460W on the first image is actually 460VA and not 460W.
Is there a way for me to change the setup or ?
Please help :)
Venus OS
Alexandra avatar image
Alexandra answered ·
@msaaby
Disable has dc system in system setup on the gx device.
I have found the Phoenix is not as good as the multiplus and quattro range in efficiency and load readings. And yes express VA not watts. In a phoenix system pay more attention to the battery readings. That is where the power is coming from and is the biggest concern in the system.
