bailey2310 avatar image
bailey2310 asked
EasyPlus 1600 tripping house RCD
Heh people.
I have an issue with the Easyplus and have no idea what’s causing it.
I’ve been running the Truma heater off the 240v while parked at home with no problems for a week or so.
Today I switched off the EasyPlus for a bit then switched it back on again and now it’s just tripping the house electric off all the time regardless of which socket ring it’s attached to.
Sequence:
I plug into house socket. Fine
Plug the EHU cable into van. Fine
Switch on EP input fine
Switch on EP output fine
Switch on the “on-off-charger” rocker to on and everything on house socket ring trips off?
What could be causing this?
Also trips when repeat sequence but switch to “charger” instead of “on”
Inverter seems to work ok
No loads are switched on or wired in while testing it.
EasyPlus
