Deon avatar image
Deon asked
Why different Battery voltages from 5kW EasySolar when power limiting?
Why would the SmartSolar or Multiplus of the 5kW Easy Solar, change the 48V bus voltage when the inverter limits its inverting output to 5kW or less (the dip is normaly due to temperature degrading)
The voltage is shown at the bttom left - it jumps from ~52.4 to 52.8V for the limiting period.
The graph bottom right indicates it is not the BMS and batteries (PythonTech 3000s)
EasySolar All-in-One
You missed posting the PV charger state?
Deon avatar image Deon klim8skeptic ♦ commented ·
Herewith the MPPT Charger and bus state
klim8skeptic avatar image klim8skeptic ♦ Deon commented ·
Your two posts, and VRM plots no longer line up in time and space.
Perhaps some plots from the same day??
