Josep morancho avatar image
Josep morancho asked
Will Multiplus temperature sensor information shared with bluesolar mppt?
I have a Multiplus Compact inverter with a temperature sensor connected to the battery. The multiplus inverter is also connected to a Cerbo GX device via ve.bus cable. In VRM Portal i see the battery tempersture info. I am planning to install a bluesolar mppt charger and connect to the Cerbo GX device via ve.direct cable.
Will the battery temperature also shared with the bluesolar to allow the mppt to improve battery charge process or it is better to install a battery temperature sensor in the cerbo gx too?
Temperature Sensor
nickdb avatar image
nickdb answered ·
You need to enable DVCC and STS on the GX and select the probe to use.
If the correct temperature compensation is set on the multi and mppt, they will then compensate accordingly.
Victron temperature sensor disambiguation table - which product supports which sensor
