jokani avatar image
jokani asked
Cerbo Relay - NC power draw?
The manual states if set the relay is set to NC there will be a power draw, anyone know what the power draw would be? And if the power is used in both closed and open states?
cerbo gx
Paul B avatar image
Paul B answered ·
The power is only used in the closed state as it has to power the relay coil. the power draw would be around 20ma I would think but to be sure you would need to test it. as I cant find any specs on that
