michael-drabeck avatar image
michael-drabeck asked
I would like to add a low temperature (charger) cut off
I would like to add a low temperature (charger) cut off, Is that possible with my Victron system?
System-
RV, no solar
Charging-
Alternator to 2 - Orion-Tr Smart 12/12/30 DC-DC Charger Non-isolated w Bluetooth
Monitor-
BMV-712 with
500A/50mV shunt
Battery-
LiFePO4 200Ah
BMS-
To be determined
Question 2
Because my DC-DC Charger’s are Non-isolated I must use a common port BMS, correct?
Temperature Sensor
kevgermany avatar image
kevgermany answered ·
Q1 Orion Tr Smart has an on off switch. It's supplied wired permanently on with a bridge wire across the switch connections. You could remove the bridge wire and wire that through a thermostat. Probably cheapest way.
Q2 sorry, no idea.
broekhuijze avatar image
broekhuijze answered ·
venus os has now the possibility for relais 1 to be temperature controlled and this can remote start or stop the dc/dccharger.
