chris-wilberg avatar image
chris-wilberg asked
Node red UI via VPN?
Has anyone figured out a way to use the node red ui dashboard remotely without going through VRM? Right now it takes me an average of about 7-10 minutes to get it to launch the node red editor every time I want to see the dashboard. I get a bunch of messages about "token expired", or "SSH timeout" over and over before the node editor actually launches. There has to be a better way!
Node-RED
Stefanie avatar image
Stefanie answered ·
Hi @Chris Wilberg,
yes that's possible and the way I do it (via port forwarding).
My Router (has it's own IP) has VPN integrated and active.
chris-wilberg avatar image chris-wilberg commented ·
Oh...I should have mentioned that I can't port forward. My victron system is on a Verizon jetpack that doesn't have an external IP address so I can't forward to it.
Stefanie avatar image Stefanie ♦♦ chris-wilberg commented ·
I don't know much about the Verizon Jetpack, but according to what I found on Google, Port Forwarding is possible. If not, then there are Providers, who offer an port forwarding service.
And I think the the Jetpack has a public IP address (from Verizon).
chris-wilberg avatar image chris-wilberg Stefanie ♦♦ commented ·
The IP that my jetpack pulls is a 100.95.9.x which is not an outward facing IP. It's internal to Verizon. I've gone the rounds with Verizon trying to get an outside facing static IP to no avail. When I do a whatsmyip.org lookup I get a totally different address of 174.198.35.xxx that I don't have access to.
I guess I just need to get a VPN figured out.
Hi, the real fix is to make opening the dashboars via VRM work well, which we know has issues and we’ee looking into it.
clives avatar image
clives answered ·
I use Tailscale, at present I have a Raspberry Pi running Tailscale which allows me to access all my computers at home from anywhere in the world. I can run Tailscale App on my iPhone (or iPad/Tablet/Mac or PC) and just fire up Safari, enter 192.168.101.70:1880.
It would be great if I could install Tailscale on VenusOS (not sure if possible, not a programmer).
https://tailscale.com
A secure network that just works Zero config VPN. Installs on any device in minutes, manages firewall rules for you, and works from anywhere.
