John Frame avatar image
John Frame asked
Multiplus II 3kva 2x120v - 24 volt availability
Is the Multiplus II 12v 3kva 2x120v available in a 24 volt version or is the 12 volt compatible with a 24 volt battery bank?
I have a client that I need to install a Multiplus II.
They already bought all the equipment from a victron dealer before hiring me.
They have a 24 volts system. They currently have four 6 volt batteries in series/parallel but they will be replaced by six battle born batteries.
When going though the system while doing my homework to check to see if they really had everything I noticed that the Multiplus II the have is 12 volt and like I mentioned they have a 24 volt system.
Is the the MultiPlus-II12/3000/125-50 @X120V they purchased 24 volt compatible?
Multiplus-IIbattery system voltage
Paul B avatar image
Paul B answered ·
No it is NOT 24 volt comparable. a 24 Multiplus II version is only available in 220volt version at this time.
You can get a Multiplus 24/3000 120v unit though
ranger-rick avatar image
ranger-rick answered ·
The 24-volt VE MP-II 2xx120v is coming out in July or August. Some solar dealers now have them on their webpages.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
