stemue avatar image
stemue asked
Problem with MPPT RS 450/100 performance compared to 250/60
ive in issue with the Performance of the mppt rs450/100
as you can see in the Pic.
Garten:
MPPT 250/60 with 2x4 REC Solar Alpha 395 (so you can devide the mesuremens by 2)
Ost/West:
MPPT RS 450/100 with 1x4 REC Solar Alpha 395
both has the same conditions in diffuse light as shown in the PIC
Cabeling is OK!
also if i switch the charge controller the MPPT450/100 does the same!
The Performance is just half of the 450/100 compared to a 250/60 on the same array.
Any Idea looks for me as the 450/100 has an software Issue.
KR
Stefan
MPPT Controllersmppt rs
kevgermany avatar image
kevgermany answered ·
Please post the configuration settings of the two controllers.
stemue avatar image
stemue answered ·
hi
RS 450/100
Firmware is 1.05
Network Control
cant see the Networked Operation as there is no Menupoint in the cerbo
(shouldnt there be a menu like for the 250/60 with Networked Operation where i can see the status? its the first VE Can device i use)
MPPT 250/60
Firmware is 1.59
Charge Voltage 52,40V
Charge Current 17.6A
(the third controller has a charge limit of 16.1A so still 16.3A chargelimit left for the 450/100)
Both Controllers are Nework Controlled (BMS Controled from Pylontec Batterys)
SOC of the Batterys is 40%
Charge/Discharge limit set from BMS 50A
stemue avatar image
stemue answered ·
for me it looks more like a mppt tracking issue
the voltage of the array in the 450/100 is way higer then it should.
the 250/60 150v (4 in a row)
the 450/100 180v (4 in a row)
all same pannels
Alexandra avatar image
Alexandra answered ·
@stemue
The voltage start and operating range of the 450/100 and the 250 are vastly different.
The 250 will start tracking from 5v above the battery. The 450 will not do this, it is designed for high string voltages.
The 450 will only start operating at 120v and can use the range 80v to 400v. But the algorithm is also affected by battery voltage. See the tech spec section of the manual.
So what I am really saying is you need a higher string voltage to make the 450 work better. Take your 2x4 and make it 1x8 if it meets the requirements with voc and battery float and you should have a banging system there. It is being wasted with a 4x1 string and the 4x2 string.
stemue avatar image
stemue answered ·
allready did the change to 1x8 as i thought the same but it didnt work well wich takes me to the point i am now to test. even if the 450/100 is for higher voltage range it should work ok at 160v mppt and 200v oc on a string. for shure it does but the Pylontech are 15s lifepo4 so voltage is 45v to 52,5 as in the pylontech specs. so we are in the range of the specs on both sides on the battery voltage and the PV voltage or do i miss something ? at the time of the screenshot the battery voltage was at 49.5v
@stemue
Think you answered your own question then. It will work ok for 160v or 200 voc but there is a better product for that range. Having a lower voc puts the rs450 at a disadvantage. Its a good unit you are just applying not using its particular abilities.
Pylons usually float at 51v so your voc should be closer to 8x51v so slightly less that 408voc.
I have seen the behaviour you are talking about with a few different inverter brands with 450v mppts. If you arent running higher string voltages they do not work well.
Their start voltage is quite high and like I said the 250s 150s etc start just above battery voltage. (The 450s are over 2 times the battery voltage to start). So a massive advantage for the 250s and in your case a better choice for your pv setup.
baxter avatar image
baxter answered ·
@Alexandra
I am wondering why the Rs450 ist not working fine with 1*8 modules. This should be a Voc of around 320V or more for STC? For a 450V MPPT this should be perfect?
Or let me ask in a different way, what ist the best performance range of the RS450 in terms of Voc and Vmpp for 54V float?
TIA
mterman avatar image mterman commented ·
@Baxter
Did you have any luck with this?
baxter avatar image baxter mterman commented ·
unfortunately not
stemue avatar image
stemue answered ·
it looks like the RS450/100 has some software issues.
MPPT Tracking is not working that good. MPPT working voltage is 10% higher then it should be. You loose 10%+ of the power you get on optimal MPPT tracking. Shadow management is not working well. So i opened this thread to give Victron a hint that there is a problem. At moment i would not buy this device again and would better use 2 60/250 if possible even if you dont need shadow management and would 2 strings in parallel on the 60/250. Maybe Victron is able to solve this issues with future softupdates. But for now its that way in my perspective.
250s are better and safer/easier to work with if your panel cable runs are not over 30m.
Henning Schewe avatar image
Henning Schewe answered ·
I'm just thinking about buying the rs450 / 200 for a configuration with 1 x 9 modules each mppt and Voc around 400 V. If I'm right this would be in the optimum tracking range for the rs450.
Reading the thread, I am quite confused after all. Even the operation with 1 x 8 modules does not seem to deliver the optimum (see above). I would be grateful for further comments from Victron.
@Henning Schewe
I have a site with 6x 450/100 installed 7x 2 strings each of 400W panles. We get max performance out if the panel array for the irradiance levels we have.
Max VOC is calculated on float voltage of the battery for the RS 450.
