picotfloyd avatar image
picotfloyd asked
100|30 charging at 16v high voltage on 12v FLA bank
65912459892-1ff7f607-5928-43f4-a389-3c97a0a1d180he.jpegSystem:
3 Victron 100|30 SmartSolar chargers and one 30amp generic cc.
Each attached one cc to one 405W solar panel. (four panels, one charge controller each)
All charging a 12v FLA 4-battery bank connected in parallel for 800Ah
SmartShunt and SmartBatterySense are also all in one VE.Smart network.
Problem:
My inverter was not working properly so I checked battery voltage. The voltage off of the recently purchased batteries was >16V!! Three Victron CCs showed 12v charging, but somehow 16v was being introduced. I disconnected the no-name CC, but no change. I disconnected the starboard 100|30 and voltage into the system dropped to 15.5 (still way over 14.4 charging voltage.) I disconnected the center panel 100|30 SmartSolar charge controller and voltage in the system went immediately to 14.4v. I added the 3 chargers back one at a time with a close eye on the voltages, but no further issues were seen.
I have been using these controllers since 2018 with no issues (panels upgraded 18 months ago, batteries replaced 3 weeks ago (1000 + daily use FLA died as expected)
Help needed:
Anyone have any insight into how this can happen or what I can do to prevent it from occurring? Those voltages could kill a battery pretty fast.
Additional detail:
This was observed as a problem about 2 hours into my charging day, 10am, it could have been going on for up to 2 hours, but no longer. Charging continued the rest of the day with no issues. system shows 6 hours bulk, 3 hours bulk and 1hour float now that the charging day is done.
MPPT SmartSolarbattery system voltageovervoltage
You have SmartSolar MPPTs so use the VictronConnect app to check the settings.
picotfloyd avatar image picotfloyd commented ·
I used Victron connect app -- all settings are as before, using normal 12v battery charging profiles.
controllers are all using latest firmware.
picotfloyd avatar image picotfloyd picotfloyd commented ·
equalization voltage is showing 16.2, but all three controllers show automatic equalization set to DISABLED
picotfloyd answered ·
Here are the settings:screenshot-2021-11-21-at-125948-ampng.jpeg
Any other ideas why charging ran away and went to 16+v ?
the chargers have worked providing normal 14.4 volts for years, that one morning voltages drove up to 16+ volts. any ideas on why this could happen? @Matthias Lange - DE
kevgermany avatar image
kevgermany answered ·
Perhaps you accidentally started an equalisation cycle
is there any logging for equalization cycles ? I have not been able to find any information about this. I was not logged into any of the 3 chargers before the voltage bump to 16+ volts occurred. all 3 are set to "Disabled" for equalization and I rarely (never) even look at this page in the VictronConnect App.
The mppt records min and max battery voltages for each day.
Post a screenshot of your mppts history (detailed).
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
