Adam Hanafi avatar image
Adam Hanafi asked
Low Battery Alarm - MK3 Settings Screenshot
Hope all is well , purchased a second hand multiplus , installed and got a "low battery" flashing led , purchased an mk3 connect , settings are normal and should not be causing such an alarm. Any ideas? It seems like the multiplus is reading the correct voltage at 13.3 , the low voltage dc alarms are set much lower , pls help
Help
Adam Hanafi answered ·
solved - i had to delete the VE BUS BMS , why is that there ? smh
Paul B avatar image
Paul B answered ·
I suspect that previous owner installed the VE BMS Assistant.
