Ronald avatar image
Solar Design - Need assistance
I am busy designing a off grid solar system for myself... I am not a qualified electrician and did all my research on the internet and reading lots on the Victron Web sites.
I want a 10kVa system (+/-).
So:-
20 x 330 Watt Panels (connected in series in 5 strings of 4 panels)
into 1 x connector box (with a fuse on the positive (LS BKN C63A (230/400V~))
Connected to:
1 x Victron Energy MPPT 250/100-Tr
1 x Pylon US2000B Plus 9.6kWh Li-Ion Battery
1 x Victron Energy Quattro 48/10 000/1401
do i need anything more?
Ronald Wagener
offgrid
Boekel avatar image
Boekel answered ·
Yes, you need an installer, and / or Victron distributor to walk through the system, and to (help) install it.
-your battery needs to be at least 2x the size, and probably 3x/4x in practice due to battery limits based on temperature, SOC, etc.
-you need a Venus device to let all components communicate with each other and bms
Share
